451 Turbo on a 400 Case ?????
Lamont
10-29-2005 19:23:18
Anyone out there ever try this?
Eldo case
10-30-2005 09:57:02
 Re: 451 Turbo on a 400 Case ????? in reply to Lamont, 10-29-2005 19:23:18
Do like we did put a 504 cid in a 830 eagle hitch. A 400 would be the same. One bad boy with a 10mm pump and .020 injectors a bigger turbo don't forget bigger lines and a beefed up clutch!!!!! !!!!! !!
Lamont
10-30-2005 11:46:44
 Re: 451 Turbo on a 400 Case ????? in reply to Eldo case, 10-30-2005 09:57:02
How creative did you have to get coupling the engine to the transmission? Were they even close?
Eldo case
10-30-2005 16:04:44
 Re: 451 Turbo on a 400 Case ????? in reply to Lamont, 10-30-2005 11:46:44
Bolted right up. Fuel line and we used the 900 steering. You might have to do a little grinding on the left front block for the steering shaft on a 400.
Eldo case
10-30-2005 10:44:05
For a photo of my son's tractor go to the tractor photos. Looks pretty good I think!!!!!
Lamont
10-30-2005 11:54:46
 Re: 451 Turbo on a 400 Case ????? in reply to Eldo case, 10-30-2005 10:44:05
Looks great. That's sort of what I had in mind.
Gene Dotson
10-29-2005 21:09:03
Too big of a turbo for the 400. Not enough gas flow to spin it fast enough to get much boost. I ran a Corvair turbo on my 700 diesel for a while. Turned about 95 horsepower in the field, but the heads cracked from the excess heat... Gene
Lamont
10-30-2005 06:02:51
 Re: 451 Turbo on a 400 Case ????? in reply to Gene Dotson, 10-29-2005 21:09:03
I was referring to the entire engine as well. Should have been clearer on that.
