davidbrown 885
bill in la.
10-29-2005 18:18:33
trying ID tractor for age & info. i can get about this tractor.
s/n # 885/1 11017196 eng.355011 50775 reduction ratio 9/37
this is all info. on data tag. I found same s/n stamped on frame. thanks for any help i can get.
RPoff
10-31-2005 09:48:26
 Re: davidbrown 885 in reply to bill in la., 10-29-2005 18:18:33
I have one of these. Great tractor. 3popper diesel, starts hard in the cold though. What do you expect from a 70,s model. No plans to restore as of yet, it is still too good. Use on a small farm. Check thru the links on this page, seems I remember finding specs on it somewhere in here. I seem to remember that they stopped making around76, maybe 40-46 horse drive/pto power. Enjoy it.
bill in la
10-31-2005 19:39:39
 Re: davidbrown 885 in reply to RPoff, 10-31-2005 09:48:26
thanhs for info. (handle) south texas case gave me info. it is a 1979 40hp.
bill in la
10-31-2005 19:39:29
bill in la
10-31-2005 19:39:22
South Texas Case
10-30-2005 07:56:43
If you're looking for used parts try Eagle Tractor, Eagle Lake, Tx. I don't think nrw parts are any problem to get from the dealer. I know a source for wiring harnesses if you need it I'll try to look it up. Good Luck Tony
South Texas Case
10-29-2005 21:22:15
My book says 1979 model, 40 HP & 4400 lbs dry weight. Tony
bill in la.
10-30-2005 04:43:17
 Re: davidbrown 885 in reply to South Texas Case, 10-29-2005 21:22:15
are parts easy to come by , looking for pully on p/s punp, may also need another pump.
Baz
10-31-2005 20:32:47
 Re: davidbrown 885 in reply to bill in la., 10-30-2005 04:43:17
We are DB specialists in New Zealand. We have new pulleys in stock. These usually flog the centre out and damage the shaft as well. We have new shafts on their own. And seal kits. The actual pumping elements are generally long lasting.
Barry.
bill in la
11-02-2005 19:25:18
 Re: davidbrown 885 in reply to Baz, 10-31-2005 20:32:47
barry, could you e-mail me price of new pully plus shipping. address [email protected] thanks, bill.
bill in la.
10-30-2005 07:16:23
just ordered manuel , looking for wire diagram to get ahead start. [email protected]
