Head Torque
chiefrider
10-28-2005 21:11:07
Does anyone know what the head on a flathead Continental engine should be torqued to? VC Case tractor.Book I have just says to tighten evenly.
WALTER T
10-29-2005 00:16:15
 Re: Head Torque in reply to chiefrider, 10-28-2005 21:11:07
THE HEAD TOURQE IS 45 LBS START FROM THE MIDDLE AND TIGHTEN THEN TOURQE THE HEAD DOWN FROM MIDDLE AGAIN. USE NEW HEAD BOLT'S AS A NOTE TO YOU. IF YOU USE USED BOLT'S THEY WILL NOT HOLD.
chiefrider
10-29-2005 01:06:45
 Re: Head Torque in reply to WALTER T, 10-29-2005 00:16:15
This engine has studs in the block with a nut and washer on topof the head.
