Waterpump Grease?
Engineer20
10-26-2005 19:14:37
The manual for my LA says to use "special" waterpump grease for the grease cup. What kind of grease are they talking about. I'm guessing it has something to do with temp.??? Any help?
Thanks,
Mike
Steve-MN
10-28-2005 16:35:56
 Re: Waterpump Grease? in reply to Engineer20, 10-26-2005 19:14:37
Just a grease note. I'm restoring my fathers 49 LA & he was a real 'grease nut'. "Grease is cheaper than parts" he always said. He made us kids give the water pump 1 shot of grease every nite for years. I just tore into this LA for the first time(4000 hrs) & the entire inside of the water jacket is coated with a very thin layer of grease. Nothing is rusty & everything is coming apart REALLY easy. Even the water pump came out with no problem. I don't think you can hurt by over greasing a little.
Good luck!
Steve
Gene Dotson
10-27-2005 05:03:01
The waterpump grease recommended is a graphite based grease. Most any heave graphite grease will be compatible... Gene
AllanC
10-26-2005 21:13:56
They used to sell quite a stiff waterproof grease as waterpump grease. You can still buy waterpump grease but it's thinner than the old stuff. It still works O.K.
