Case L - Zenith carburetor jets
Steve (DE)
10-25-2005 19:43:10
I'm rebuilding the Zenith K-6 carburetor from my Case L. Someone has been at the main jet before me. The jet seems OK, but the screwderiver slot is buggered. Is there a a source of replacement jets for these carbs? I have two K-6 carbs, one is an earlier model than the other. The one I was planning to put back on the tractor is the earlier one, and the main jet has a number 35 stamped into it. The other carb's jet has a number 38 stamped on it. Anybody know what these numbers mean. Are the jets interchangeable in the carbs?
Why do I seem to be the only one asking these arcane questions?
Doug Boll
10-27-2005 05:44:30
 Re: Case L - Zenith carburetor jets in reply to Steve (DE), 10-25-2005 19:43:10
The number is in reference to the orifice diameter. A set of wire bits can make them the same or anything you want them to be! They should interchange.
