730 Cylinder heads needed (gas)
segrat1
10-25-2005 19:00:50
Looking for a set of heads for the 730 Case-O-Matic (gas). Must fit the A234 block. Anybody got a set that are good and not doing anything.
segrat1
10-25-2005 19:56:18
 Re: 730 Cylinder heads needed (gas) in reply to segrat1, 10-25-2005 19:00:50
Its been a good tractor with everything working but the person who was mowing with it overheated it when there was a leak in the lower radiator hose. Believe it or not the guy runs a air tour business with his plane. Don't think I'll fly with him.
Thad
10-26-2005 03:50:12
 Re: 730 Cylinder heads needed (gas) in reply to segrat1, 10-25-2005 19:56:18
Well i would take Dons advice and check it out a little better. If he cant help you with all that you will need if you fix it i can. As far as the man who flys i will pass on a tour at this time. Thad
segrat1
10-26-2005 09:06:20
 Re: 730 Cylinder heads needed (gas) in reply to Thad, 10-26-2005 03:50:12
What would it cost for a pair of good 730 cylinder heads?
Don L
10-25-2005 19:36:30
You need sleeves and pistons,and two heads. Best check the rod and main bearings out, to see if it needs grinding. You have to decide if it is worth fixing. Is the Case-O-matic known to be good? PTO? HYDS? Could a big money pit.
Don L.
