J I CASE 1090, Built in 1970
Don L
10-25-2005 17:09:02
What is the little known JI CASE MFG tractor called a 1090? Built like one year, and used a 451 ci engine in 1970 . Can someone lite a fire on the subject? Pics? Case announced the "90" series in Sept of 1978.
Don L.
oldl
10-28-2005 08:46:09
 Re: J I CASE 1090, Built in 1970 in reply to Don L, 10-25-2005 17:09:02
Don,
The 1090 was built in 1970-71. It was basically a heavy-duty 1070, using the 1170 front end components (heavier axle, spindles and hubs), side rails, increased hydraulics and heavier 3-point components. The 1090 uses a bar rear axle instead of the outboard planetaries used on the 1170. The engine is the normally aspirated 451BD used in the 1070, putting out the same 108 hp. From what I understand, there were about 300 built in 1970, and a little over 100 built in 1971.
I've got a 1970 1090 sitting in my shed awaiting an engine overhaul. Equipped with wet 23.1X30 tires and weighted up, it passes the scales at a little over 16,000. Good old tractor, just wish the cab was quieter! I ought to take some pictures and post here when I get time.
Oldl
c hess
10-26-2005 18:23:19
Reling on old memory but i think 1090 came with side rails like 1170 an might have had a oil cooler. not sure of that. Question for owner of 1170 another person wants to know if you can turn dish on rear wheels of 1170 . He wants to get wide to mow hilly ground
c hess
10-26-2005 18:23:27
Tom Railsback
10-26-2005 17:39:48
THere is a picture and a short writeup about it on p. 49 of Stonehoue & Brumbaugh's book.
Thad
10-25-2005 17:51:33
How many pics you want Don? I have two to pic from. Just ran the one in the shop for a powershift job. They are not like a 90 series. They are basicly a 1170 without the turbo and have either 8 speed or powershift. One stout built tractor. We have had several thru the years that we have sold. One of mine is for salvage the other the one im fixing will be for sale later on. They came in a series of three types. You had Rice, Delta, and Western. I will take some pics tomarow and send you. Thad
