case 430 ck still leaking oil from differential
Mike Christy
10-25-2005 12:10:37
I have recently replaced the oil seals for the differential sidegears on my 430 ck. I still have a substatial leak at the seals. The seals were replaced without damage to the seals but the side gears seam to be a very sloppy fit with alot of movement. I am in need of some advise as to what to do next. I"m thinking either the differential sidegear bearings or the thrust washer/shims for the sidegear. can anyone make any suggestions? Please!!!
Roger (Mi)
10-26-2005 04:09:39
 Re: side gear oil leaks in reply to Mike Christy, 10-25-2005 12:10:37
If all of the shims between the transmission housing and the side gear plates are removed, it's going to be very difficult to adjust the ring and pinion for the needed .008 (in) backlash clearance. The side gears should NEVER be installed in such a way as to allow the ring gear to wander. That .008 clearance MUST be maintained. You are correct about either replacing the side gear bearings or placing shims between the side gear bearings and the side gears. Use shims only if the bearings are in great condition. Remember, those side gear seals are easily damaged during installation of the side gear plates unless very thin metal (beer can, soda can) are wraped around the ring gear shafts. Once installed, pull the thin seal protection out. Good luck.
Patrick in ME
10-27-2005 07:09:04
 Re: side gear oil leaks in reply to Roger (Mi), 10-26-2005 04:09:39
I've even had good luck using a 40 mil plastic sheeting to cover the ring gear. The plastic is really easy to install over the gear. It's thin enough and slick enough to slide the seal over yet tough enough to protect the seals.
