Waterpump Questions??
Engineer20
10-24-2005 18:47:22
Hi all,
I'm restoring my 1950 LA. This is my first restore. I'm trying to get all of the problems taken care of before I have it painted. I've begun to notice water leaking from around the water pump. My question is..... Is the waterpump a one piece unit that I remove and have the whole thing taken somewhere and rebuilt or is it a matter of just replacing some parts that I can do myself at home.
Thanks for all your help!
Mike
Gene Dotson
10-25-2005 02:24:58
 Re: Waterpump Questions?? in reply to Engineer20, 10-24-2005 18:47:22
Mike; Have you filled the grease cup and applied pressure with grease? The LA , and most Racine tractors had a grease pressure seal in the pump. Fill the cup with heavy grease and turn the cup down till you feel pressure. This should stop the leak. As for pulling the pump for rebuild, the pump has a double flange and 3 tapped holes for 1/2 inch puller bolts. Sometimes, if you are living right, the pump can be removed with these puller bolts. Most often the rear flange of the pump is rusted in the bore and trying to pull the pump can break the pump housing. The only way to remove a rustad in water pump is to pull the head, remove number one piston and sleeve and knock the water pump out from the back side... Gene
Don Livingston
10-25-2005 05:29:38
 Re: Waterpump Questions?? in reply to Gene Dotson, 10-25-2005 02:24:58
Very true Gene. My hired man broke the waterpump and the BLOCK, tring to get off the waterpump on a LA last week. I was not happy. D.L.
Gene Dotson
10-25-2005 10:21:09
 Re: Waterpump Questions?? in reply to Don Livingston, 10-25-2005 05:29:38
Don, I am still tolerating my leaking pump on my LA. I can run it all day without leaking, but as soon as I shut it down, I have to turn the grease cup in to stop the leak. I plan to rebuild the engine this winter and will then romove the pump and install a new seal. I just know all of that used grease is accomulating in the engine block... Gene
wayne2
10-24-2005 20:03:49
I THINK!! easier to replace,hassle of packing, etc. beyond parts man knowledge, he retired last year. LOL but true. Wayne
