430 Case
haroldinky
10-24-2005 13:12:39
I am thinking about fixing up my Dad's 1969 430 case. It's a diesel and I wandering what the HP is on this old tractor?
paulver
10-26-2005 15:28:36
 Re: 430 Case in reply to haroldinky, 10-24-2005 13:12:39
I've been considering doing exactly that on my 430. I'm all for increasing the HP, but will the transmission stand up to the added pulling force?
Roger (Mi)
10-31-2005 03:53:13
 Re: 430 Case additional power in reply to paulver, 10-26-2005 15:28:36
Tranmissions are basically the same. However, the cooling systems on both the 530 & 630 are BIGGER! It would NOT be a good idea to continuously use it at that power level.
Roger (MI)
10-26-2005 04:32:08
 Re: 430 Case diesel in reply to haroldinky, 10-24-2005 13:12:39
While the diesel was rated at 35 horsepower by the factory, the diesels always produced about 5 more horsepower than the rating. The 530 & 630 diesels are the same (188 CID). However, the fuel injection pumps were set differently for each application. The 530 was rated at 43 horsepower and the 630 was rated at 52 horsepower. Can the 430 pump be set to 630 specs? Yes! However, the pump must be removed from the engine and taken to a fuel pump injection service. They can reset the pump to the higher internal RPM and fuel delivery.
Jim Gundlach
10-24-2005 18:42:23
The 430 was advertised at 34 hp when they sold them. However it is exactly the same engine as the 530 with slightly different fuel injector timing that was rated at 40. Some say Case under stated the 430's hp to help justify the higher 530 price. On tractors this old, the timing on the fuel injectors are almost as likely to produce 40 hp on the 430 as on the 530.
Mike in MI
10-24-2005 15:53:13
Harold,
The 430 Case diesel is 34 HP.
Mike
wayne2
10-24-2005 20:08:00
 Re: 430 Case in reply to Mike in MI, 10-24-2005 15:53:13
If I had it I'd be into it like---- on----,it'll be yours look at it,touch it,feel pride,brag it up,kick it , it'll be yours Enjoy(beats buying new)
