case 310B battery
PREGIER
10-24-2005 09:30:44
I just bought a 1959 310B and I cant seem to get the battery to charge, before I look too far into it, I would like to know if this is a positive ground circuit? It is hooked-up as a negitive ground, but should it be?
Thanks in advance
Patrick
Scott Flynn
10-24-2005 10:07:25
 Re: case 310B battery in reply to PREGIER, 10-24-2005 09:30:44
I have the same tractor. Ours is 12V negative ground. The owner's manual also indicates that these tractors have a negative ground 12V system. I think the earlier 310 (roundnose) may have been different.
pregier
10-24-2005 15:51:54
 Re: case 310B battery in reply to Scott Flynn, 10-24-2005 10:07:25
Thanks, That helps, I will check that off my list of posible problems. I know its not the generator becuase it is putting out 60 amps. so next I will check the regulator.
