case L value
Flambeau 1
10-23-2005 17:21:47
I"m looking to purchase a 1933 Case L. The tractor has an okay paint job, 25% tread on tires and leaks a little coolant in the crankcase. seems to start decent and run good. I"m not that familiar with the L, LA models. Anything specific I should look for with this model before buying?
L.C.Grey
10-23-2005 18:50:58
 Re: case L value in reply to Flambeau 1, 10-23-2005 17:21:47
Not a lot to watch out for on the Ls really. I'd look at originality in manfolds, magneto and carburetor etc, before giving top dollar. Most parts and pieces are pretty easy to come by, not too expensive. Are you saying it is leaking coolant into the oil? Bad O-ring on a sleeve maybe... hopefully nothing worse.
As far as sale price, it all comes down to location. Where you are and where the tractor is. In some parts of the country there's Ls everywhere and others there's hardly any.
I was told that I was paying way too much for my '29 L by someone up north, but here in Texas it seemed cheap, since it was the only one I'd ever even seen at that time. I sure couldn't have gone up to Minnesota and got one for the difference in price.
Around here I wouldn't think $1500 would be a bad price for a fairly straight running L. I sure wouldn't take that little for mine, but someone somewhere else might think I was way overpriced.
I know my answer wasn't too definitive, but even being there to see the machine different folks will form vastly different opinions. The bottom line is "how much do I want it". If you're happy with what you get then I'd say it was worth what ever it cost.
flambeau 1
10-23-2005 19:49:25
 Re: case L value in reply to L.C.Grey, 10-23-2005 18:50:58
I"m located in Eastern WI. Everything is original except for the wheels. It has cut downs on the front and F&H round spoked rubber on the back. The intake manifold is original but cracked. I think that is pretty common on c"s and L"s correct?
Glenn F.
10-23-2005 19:36:04
What an excellent, well thought out answer. Glenn F.
