David Brown 850 front end loader
PhilipD
10-21-2005 19:34:50
does anyone have any idea how the controls for the front end loader work. I assume it must be some combination of the 3 valve control and some other control valve which I have yet to locate.
Unfortunately, the owner of the tractor was deceased and so far I am just trying trial and error with little success
MJ in the UK
10-25-2005 09:32:30
 Re: David Brown 850 front end loader in reply to PhilipD, 10-21-2005 19:34:50
Yes Phillip you turn the valves all the way out to operate a service and all the way in to isolate it. MJ
MJ in the UK
10-24-2005 09:36:48
Sorry Phillip i forgot to say that the valves you are not using must be turned off. MJ
PhilipD
10-24-2005 15:32:46
 Re: David Brown 850 front end loader in reply to MJ in the UK, 10-24-2005 09:36:48
Dear MJ
Thanks for the help. Just one (hopefully) last question. To turn off the valve do you turn it fully in or fully out?
with thanks
Philip D
MJ in the UK
10-24-2005 09:33:48
Hi Phillip. The L on the 3 way valve is for the 3 point lift operation. The loader can be piped into NO 1 or NO 2 outlets on the valve. MJ
MJ in the UK
10-22-2005 07:28:40
Hi Phillip to work your loader you want a 3 way valve fitted to the left of the drivers seat. This valve has 3 knobs on it 1s knob works the 3 point lift 2nd knob works the tipping trailer hose 3rd knob works the loader. This valve was standard fitting on all UK tractors. MJ
PhilipD
10-23-2005 15:20:30
 Re: David Brown 850 front end loader in reply to MJ in the UK, 10-22-2005 07:28:40
Dear MJ
I found the 3 way valve. I have a couple questions. Do you have to close the flow to the 3 point lift and remotes for the loader to work? IF so, is closed fully in or fully out. I see the valves are labelled 1, 2 and L. Would it be safe to surmise the L stands for loader?
With thanks
PhilipD
