CASE 311 grille and side panels needed
Smoky
10-21-2005 05:56:49
I would appreciate any leads to finding useable or salveageable grille and side panels. Are these being reproduced? sources?
Roger Hornbaker
10-21-2005 10:07:15
 Re: CASE 311 grille and side panels needed in reply to Smoky, 10-21-2005 05:56:49
Smokey: I do have reproduction parts for the Case 300 round nose, "56 and "57 models. Roger300
wayne2
10-22-2005 04:36:52
 Re: CASE 311 grille and side panels needed in reply to Roger Hornbaker, 10-21-2005 10:07:15
What do you get for them??
Jim B.
10-01-2006 18:37:19
 Re: Amp meter wiring in reply to Bob, 09-30-2006 01:09:27
Not "ALL" ... don't run the starter current thru the amp-meter, it cannot carry the load. Make sure the connections are made on the battery side of the starter solenoid.
Roger Hornbaker
10-22-2005 06:05:59
 Re: CASE 311 grille and side panels needed in reply to wayne2, 10-22-2005 04:36:52
Wayne2;
Would you mind opening your email, I don't want to go against YT regulations or CaseIH's by advertising on this forum. My PH. 301-223-9005
Roger300
Have sent my items, most of which I make, out on the honor system and accept personal checks with out a waiting period.I think you should see the items you're buying. So far all have paid and replys all favorable. Is this advertising?????
J Croley
04-28-2006 11:29:55
 Re: CASE 311 grille and side panels needed in reply to Roger Hornbaker, 10-22-2005 06:05:59
Hi,I need side panels for a case 311. Please let me know if you have them available.
Thanks,
J croley
wayne2
10-21-2005 06:09:31
Can be difficult,had my round nose for 10-11 yrs. and no luck w/o giving up 1st son, and substancial $$$. Maybe you'll get lucky though. hooked small heavy chain to mine and started yarding logs,she dosn't seem to mind, used expanded steel for my Rad. grill. Wayne
