Case 310B PTO seal leaking
Scott Flynn
10-20-2005 16:21:14
Just drained the oil in my transmission and replaced the seals on the pinions to stop oil leaking on to the brakes. While we were doing that my brother and I replaced the seal around the PTO - because we suspected that it was leaking as well. It can be hard to tell since it is behind that plate for the guard. The outer portion of the seal had worn out, but inner portion of the seal still had kept water out and at least some oil in. The outer part had rusted and there is some pitting on the shaft. We cleaned up the shaft the best we could with emory cloth.
When replacing the PTO seal, we noted that the new seal is much "lighter" than the one we were replacing. There were several "layers" in the old seal, but only one outer one with a big hollow area in the new one. Sure enough we filled it back up tonight and it is leaking around the PTO like a sieve. Does know if this seal crosses with a non CNH seal or have any NOS of this part with the heavier seal?
Scott Flynn
10-20-2005 16:22:25
 Re: Case 310B PTO seal leaking in reply to Scott Flynn, 10-20-2005 16:21:14
The Case part number is G13803, which is still availabe from CNH under the same number.
