case 1170 with planetary wheels - very narrow
Jim Poletti
10-18-2005 18:44:57
I got a Case 1170 with the planetaries. It's rear wheels are set narrow. I read the manual but can't see how to get the wheels spaced farther apart. I can see gaining 4 inches or so by moving the clamps to the wheel to the inner band, but that's all. Help. Jim
c. hess
10-19-2005 06:02:00
 Re: case 1170 with planetary wheels - very narrow in reply to Jim Poletti, 10-18-2005 18:44:57
Got your other message. Asfor removing glass sight glasses use a pliers an cover glass with cloth- turn gently an they will come out than you can clean them an be able to see if trans is full. As for wheel spacing i checked neighborsan they are about 35 in on center. Buy moving rim to inner ring you will gain 4 inches more . oOn his he can also move clamps in other hole in casting gaining anotther 2inches. This would give him about 80inches from center to center on tires. Maybe someone has a book an can help.
