Help Finding CC Parts
Fred in Utah
10-18-2005 08:28:28
I need some parts for my 1937 Case CC-3 I�m trying to restore. I need push rods, head gasket, carb kit, and exhaust manifold. Are there new parts still available for this tractor? Where are the best sources? Any leads would help.
Furthermore, what are the causes for bent push rods? Two cylinders had significantly bent rods with the other two having a small bow. Do I only need to look for the cause on the top end? This tractor has been sitting in the field for 20+ years. Rust is my main enemy. One exhaust valve is stuck open. Do I need to replace the valves or can I just clean them up? My goal is to have a �good looking� tractor that runs well and can do a little work. Thanks.
dctom
10-18-2005 10:21:57
 Re: Help Finding CC Parts in reply to Fred in Utah, 10-18-2005 08:28:28
STUCK VALVES WILL BEND PUSH RODS ASAP!! POST FOR DON L HO HERE HE CAN HELP YOU WITH YOUR PARTS TOM
Fred in Utah
10-18-2005 12:04:26
 Re: Help Finding CC Parts in reply to dctom, 10-18-2005 10:21:57
Thanks Tom. I'll post for Don.
