Removing Front End Loader
Chuck MA
10-17-2005 20:08:29
I would like to remove an old front end loader from my 58 Case 300 to paint the sheet metal on the tractor. On this model the sheet metal extends over the mounting holes for the loader. This is an old superior type loader which had originally held the hydraulic fluid in the frame. What I am concerned with is, just how to take it off after unbolting and disconnecting it, and will it line back up to the mounting holes to reinstall.
Thanks Chuck
mark in mass
10-19-2005 16:46:08
 Re: Removing Front End Loader in reply to Chuck MA, 10-17-2005 20:08:29
Hello Chuck, I recently had mine off, and the backhoe too. It was not hard, just had to find enough jacks and enough stands to hold everything.
Question, does yours have the hydraulic filter on the front? Mine does and I am looking for the filter make and number. Thanks.
Oh, what part of MA are you in?
Chuck MA
10-20-2005 17:30:36
 Re: Removing Front End Loader in reply to mark in mass, 10-19-2005 16:46:08
Hey, Mark I live in North Central MA, in the Town of Templeton. I don't have a back hoe, but it does have an eagle hitch. I think the loader was made by Superior. The hydraulic pump for the loader is attached to front but not filter. Mark where are you located and what model tractor are you using? Thanks
Chuck
Mark in mass
10-21-2005 01:31:46
 Re: Removing Front End Loader in reply to Chuck MA, 10-20-2005 17:30:36
I"m in Uxbridge, a litttle south of Worcester.
Mine is a 310b, with backho and loader. Good luck.
