float from carb repair
indypower
10-17-2005 19:07:19
Does anybody repair floats from carbs and have success! If they do what is the best method of doing so. I have carb form a dc that i am overhauling and the foat has gas in in it. Was just trying to figure out the best way to repair them.
Glen in TX
10-18-2005 09:05:30
 Re: float from carb repair in reply to indypower, 10-17-2005 19:07:19
Takes time to wait on that new float. Some larger floats are $40-$50 also.
Best float repair instructions I have found are on this site: www.thecarburetorshop.com
Heat up a pan of water and hold the float with pliers in the warm water, not boiling and you will see air bubbles spewing from the leak.
Usually not needed to drill another hole as if you look most floats already have a vent hole from the manufacturing process. Drill out vent hole or if float is dry inside unsolder the vent hole. Drain float and let it dry out.
Then use some steel wool or fine wire brush to clean the leak area well. I find a good electronics solder works well. The no lead type. Use the solder and or flux that works best for you. Solder up the leak hole and then solder shut the vent hole opened earlier. Then file off excess solder and test for leaks again. I've had some success fixing floats while others will have leaks in a area that may be a problem to fix and you just have to replace those. Good luck.
John Saeli
10-18-2005 04:33:16
Hey Indy: We stock a new float here.
oldrusty
10-17-2005 19:23:18
I have used low temp solder on them and had good luck
Joe (Wa)
10-17-2005 21:04:19
 Re: float from carb repair in reply to oldrusty, 10-17-2005 19:23:18
Drill about a 1/8" hole near the crack to shake the gas out and act as a vent while soldering the crack. When you are satisfied the crack is well tinned over, continue right on and solder up the hole while the float is still warmed up.
Joe
