CASE SI
PAUL PAWLAK
10-17-2005 18:28:13
I JUST PURCHASEDA AS A JUNKER A CASE SI COMPLETE WITH THE EXCEPTION OF A HUGE HOLE ON THE BLOCK WHERE A PISTON BLEW THROUGH. i'M GOING TO TAKE THE WIDE FRONT END AND THE RADIATOR AND FRONT GRILL AND SWITCH THEM TO MY RUNNING TRACTOR. MY RUNNING TRACTOR IS A CASE SC. I,M ALSO MISSING THE SHEET METAL THAT COVERS THE ENGINE. iTS A LITTLE BIT SHORTER THAN THE ONE FROM THE SC AND I DON'T WANT TO DESTOY OR SHORTEN THE ONE I HAVE IN CASE I WANT TO SWITCH IT BACK TO A CULTIVATING FRONT END. Its the metal that runs from the grill to the gas tank and covers the motor. Does anybody have any sugestions on where I may find this sheet metal? Also i'm asking for any info on the Case SI tractor. They didn;t seem to be to popular. I've seen some documentation that only 4800 were made with only 100 having the kind of front end I have which is a solid I beam . My tractor is on rubbber,where the ones from the factory came on steel wheels..can any body shed some light on this situation for m\e? ANY info I receieve is greatly appreciated
John Saeli
10-18-2005 04:32:01
 Re: CASE SI in reply to PAUL PAWLAK, 10-17-2005 18:28:13
Hey Paul: Where you located? Want another one?
