Case 2290 shifting difficulties
jcrank01
10-17-2005 07:08:57
We have a 2290 case with an 8-speed gear drive transmission. It is hard to get it out of reverse. I was wondering if this was common or how to fix it.
c hess
10-17-2005 10:18:40
 Re: Case 2290 shifting difficulties in reply to jcrank01, 10-17-2005 07:08:57
If power shift remember you have to adle to shift into reverse. If straight 8 your cables may be getting dry.
hooper
10-17-2005 07:26:54
the one that i've ran has always shifted hard. its also easy to get stuck in 2 gears at once
jcrank01
10-17-2005 08:02:33
 Re: Case 2290 shifting difficulties in reply to hooper, 10-17-2005 07:26:54
Did it shift hard in 1,2,& R or just in Reverse. Because ours shifts through them all just fine but reverse.
hooper
10-17-2005 21:19:39
 Re: Case 2290 shifting difficulties in reply to jcrank01, 10-17-2005 08:02:33
just in reverse, we have found if it you grind it while shifting into reverse (not that anyone ever does that?) it tends to get worse with time, we have pulled the side cover off and smoothed the gear tooth edges down. this is not the proper method by any means, but it beats tearing it all the way down for parts replacement. not many of the 8 speed 2290s out there, does yours have a cab?
