320 oil pump
fredit
10-16-2005 17:28:49
I just lost the oil pressure on my 320 case backhoe loader, dropped the oil pan and oil pump, the gears are worn out and cracked it looks like they skipped a tooth and caught on another tooth. Anyway it look like I am in the market for a pump (new or used) or maybe a rebuild kit if they make it. Also after inspection of the oil pan I noticed something that looks like a push rod but much to small tobe. It is about 3 to 4 inches long with a ball on one end and broke on the other I have no idea where it came from any input would be helpful Thanks
Don Livingston
10-17-2005 09:20:35
 Re: 320 oil pump in reply to fredit, 10-16-2005 17:28:49
Those pumps are well over 600 bucks new, and you have to reuse your back plate. Used pumps are around, but the shafts are loose coming thru the housing.
Don L.
fredit
10-17-2005 12:58:08
 Don in reply to Don Livingston, 10-17-2005 09:20:35
Gulf south equipement sales has them for 191 dollars
fredit
10-17-2005 12:58:00
Don L.
10-17-2005 14:40:56
 Re: Don in reply to fredit, 10-17-2005 12:58:00
You are doin better than me. I called Gulf South Eq. Sales and they didn't know anything. Good Luck.
Don L.
