case 600 selecto matic
tim bynum
10-16-2005 04:04:11
im looking at a 1958 case 600.can anyone tell me if these are good tractors and what is a reasonable price.i do have pictures of the case i could send. thanks, tim
Texas Denny
10-16-2005 19:37:09
 Re: case 600 selecto matic in reply to tim bynum, 10-16-2005 04:04:11
I believe the transmission is a Case-O-Matic. Key thing is to make sure the transmission works. It will start out in converter drive quite smoothly. If it doesn't go into gear smoothly at idle this could be a concern. You proably will not be able to shift above idle. The throttle will need to be open half way to get it moving. When you are moving, you can move the direct drive lever and there should be noticeable jerk. Once in direct drive, you should be able to throttle back to idle and the tractor will continue to move. In direct drive it should act like a solid drive. But you cannot start out in direct drive. First, it is the converter drive.
John Saeli
10-16-2005 08:37:40
Hey Tim: They are not a tractor to go out & pound everyday like their bigger kin. Parts are available for the Engine & Converter, but expensive. How's the Tires & Rims? How's the Converter Pressure? Tin all there? Eagle Hitch & Top Link there? Nice shape ready for the showroom floor, $3500. Rough, bad everything, leave it there.
wayne2
10-16-2005 07:10:50
Does it move? Read old's post he just got 800case-o-matic(jd guy with?,couple topics back)I personally have been kicking tires of overpriced dead one for couple years cause I like Desert Tan! They are more a field tractor,3-bottom-pull like hell-jury still out on trans repair-could be big bucks$$$punch in case-o-matic and view prev. posts!! Please let us know!!Wayne
tim bynum
10-16-2005 13:54:34
 Re: case 600 selecto matic in reply to wayne2, 10-16-2005 07:10:50
i posted a picture on the photo adds so you could see it.it looks to be in exelent cond all around. thanks, tim
wayne2
10-17-2005 14:01:48
 Re: case 600 selecto matic in reply to tim bynum, 10-16-2005 13:54:34
I once married a pretty gal!
