case 530 ck hydraulic
Gordon Hoover
10-15-2005 21:26:17
I bought a Case 530CK with a 532 backhoe on it at auction. It had supposedly been parked for 10 years. There is very slight evidence of any hydraulic cylinder leaks. It runs well and all the hydraulics work for the front bucket and all the hydraulics for the backhoe work except the cylinder that opens and closes (curls and straightens) the bucket. Any chance there is some simple thing I haven't heard of that would make this cylinder stick and is simple to free?
Phil (NJ,AZ, Sask)
10-16-2005 23:53:59
 Re: case 530 ck hydraulic in reply to Gordon Hoover, 10-15-2005 21:26:17
Gordon, You can repair the cylinder seals without removing the cyl from the HOE. Remove the Pin on the Bucket side (RAM).. unscrew the cylinder NUT and pull the Ram with a come-a-long (connected to Truck or other tractor)
Then put the removed Ram back on the Bucket "Pin re-Installed (so it won't rotate) You can remove the NUT & service the seals....
You can buy the PIN Spanner TOOL to remove the
Cylinder Nut but a BIG Pipe Wrench will work if your careful not to damage the ram.
Hope This Helps,
Roger (Mi)
10-16-2005 07:49:31
 Re: Most likely it's the bucket cylinder seal.. in reply to Gordon Hoover, 10-15-2005 21:26:17
There are secondary relief valves on the control valve body. If the cylinder moves well in one direction but not the other, it could have a defective secondary relief valve. However, an internal cylinder seal could allow bypass in one direction but not the other. If it has little or no power going in either direction, it's certainly a defective internal bucket cylinder seal. You'll need to take it apart and replace it.
