VAC-14 two-position switch
Russ in WI
10-14-2005 07:28:39
My battery won't charge and my ammeter says "0". I purchased the newly re-wired tractor two years ago and the battery went dead so I put a new one in (should have checked everything out first). When that one went dead I brought the generator to work and it tested ok (not sure about the voltage regulator yet though). So the question is, if a guy who didn't know the switch on the dash had 2 positions re-wired the tractor, is it possible for the generator to run on "low-charge" even though the switch is all the way out? He bought all new electrical stuff so maybe he got it wrong..... Any help would be appreciated, as the snow is coming soon and mama will need a clean driveway to get to church!! Russ in WI
Keith-OR
10-14-2005 20:05:27
 Re: VAC-14 two-position switch in reply to Russ in WI, 10-14-2005 07:28:39
third party image
Here you go with a schmatic of the wiring for Case VA series tractors...HTH...Keith
c hess
10-14-2005 18:20:40
If you cant get it to work like John said i can send you a photo of are vac dash wiring. Iwill send via Kodak as i dont know how to send on forum.
John T
10-14-2005 11:04:35
Russ, that switch basically provides a dead ground for the Generators Field for HIGH CHARGE like when lights are on BUTTTTT TTTTT T a resistive ground for LOW CHARGE like when lights are off. I guess it could be wired wrong???
If you take an ohm meter and attach one lead to frame ground and the other to the switches Field terminal (have the voltage BAT input feed wire removed) she ought to read near zero ohms for HIGH CHARGE but a few ohms when in LOW CHARGE. How does yours read????? ???
I have seen those switches not work cuz they dont have a good frame ground CHECK THAT OUT
If she charges just fine if when running you manually dead ground the Gens Field post to its case BUT NO CHARGE OTHERWISE its EITHER a bad or mis wired switch,,,,, ,,,or the switch has a poor ground,,,,, ,,or the wires open from the Gens Field post up to the light switches Field terminal !!!!! !!!!! !
If she still dont charge even with the Gens Field post dead grounded, manually by pass jump around the Cutout Relay (jump BAT terminal to GEN terminal) and see if she charges then?? If so but not otherwise, the cutout relay is bad or not well grounded or wired bass ackwards.
Make sure the Gen and Relay and Switch all have good grounds????? ????? ??? and the belt is tight also
Good luck n God Bless
John T Nordhoff in Indiana, retired electrical engineer
Russ in WI
10-17-2005 04:28:30
 Re: VAC-14 two-position switch in reply to John T, 10-14-2005 11:04:35
Thanks to all. I think I need to find original stuff to put back into the dash (atleast the pull - the new one doesn't looks goofy next to the correct ones). With the wiring diagram and troubleshooting guide I ought to be able to figure it out. Until then, I'll keep 'er on the trickle charger..... .. Thanks again, Russ.
