swap front ends on a vai and vac
noah mcnaughton
10-13-2005 17:38:08
hello i have a case vai belive 48'better parts tactor than fixer upper and i am getting a 48' vac. that does run and in better shape does anyone know if i can swap the front ends to make the vac a wide front end instead of the tricycle.
Jerry W
10-13-2005 18:43:43
 Re: swap front ends on a vai and vac in reply to noah mcnaughton, 10-13-2005 17:38:08
The front end will bolt right on as long as your VAC is not a late one (late 51 and newer) but you will have to change out the steering box as it is reverse action. The VAC needs to steer with the steering arm on the right side - the late ones do not use the arm.
Jerry
mike's600
10-13-2005 18:01:46
Take the complete Vai bolster and axle assem. swap over to the Vac.Bolts off front of engine. Make sure that assem. clears the lower studs or you will break off the bottom corner of the engine block.
noah
10-14-2005 01:56:56
 Re: swap front ends on a vai and vac in reply to mike's600, 10-13-2005 18:01:46
thank you all i am looking forward to the swap.
