8:30 Case hydraulics problem
Bart61
10-12-2005 21:14:08
Having problems. Just changed hydraulic fluid in a tractor we just bought & now hydraulics won't work. Is there somewhere we should be purging off air in the lines? How do we go about this? Please help!
c hess
10-15-2005 11:29:03
 Re: 8:30 Case hydraulics problem in reply to Bart61, 10-12-2005 21:14:08
You might try putting the left leaver eighter forward or back than trying other leaver. My 830 some on else had an it works for awhile if i do that. Know its not ate way its suppose to be. Left leaver works on eagle hitch ok. Other one(remote only works if i do the above???
John Saeli
10-13-2005 04:31:50
Hey Bart: What 830 you got, Comfort King or Eagle Hitch? Did you change the Filter? How well did the Hydraulics work before?
Bart76
10-13-2005 13:18:55
 Re: 8:30 Case hydraulics problem in reply to John Saeli, 10-13-2005 04:31:50
not sure, it's gas. Yes, filter was also changed. Hydraulics worked good before, just time for the fluid change. Now hydraulics don't work at all. What did I not do?
John Saeli
10-13-2005 16:12:47
 Re: 8:30 Case hydraulics problem in reply to Bart76, 10-13-2005 13:18:55
The only thing I can think of is that it's drawing air. Between the Pump & Suction Tube is an "O" Ring. Probably have to pull the Pump & replace that "O" Ring. I assume you filled the HYD. Oil to the Full Mark. The Comfort Kings have a Dip Stick, & the Eagle Hitch Models have a Level Plug.
