How to take of Case CC Manifold...with pic
Giant Man
10-12-2005 15:36:16
third party image
Here is a picture of my manifold (I hope)...what I need is to know how to take it off. Also I need to take off the air cleaner
Thanks in advance
Brian in Ohio
10-12-2005 18:01:18
 Re: How to take of Case CC Manifold...with pic in reply to Giant Man, 10-12-2005 15:36:16
My first answer is: VERY CAREFULLY!!
Now, to give you a truthful answer to your question... You first should take off the carb, and then the air cleaner assembly. The big hurdle is taking off the nuts that hold the manifold to the head. (I'd use a ton of PB Blaster on the nuts before I set the wrench to them.) The nuts hold on two brackets that keep the pressure on the manifold to the head. When you take the manifold off, keep in mind that the original gaskets had metal rings that went into grooves in the air openings. Make sure you pick them out.
I'm sure that a bigger authority will chime in and correct anything that I missed... Good Luck!
