800 Head Casting #
Steve Miller
10-12-2005 12:56:57
Doug, the machine shop said the casting # off my heads is 6530A. Block is #A1111. You said your heads are A8500...does that leave me out of luck with your heads?
Thanks...Steve
Doug Boll
10-18-2005 14:21:57
 Re: 800 Head Casting # in reply to Steve Miller, 10-12-2005 12:56:57
I have the heads so it is up to you, If you want them we can proceed from there, keep in touch- Doug
Steve Miller
10-12-2005 21:05:53
 800 Head Casting # - for Doug Boll in reply to Steve Miller, 10-12-2005 12:56:57
Doug, if you happen to see this - according to caseman-d your LP heads should work on my 800 gas. Would you email at your convenience?
Thanks...Steve
caseman-d
10-12-2005 16:40:30
Steve,
Gas and LP will have different casting numbers. They should still interchange, If things don't work out let me know I maybe interested in them once I'm moved.
caseman-d
