Case ScC I have spark No Gas!
RShaips
10-11-2005 16:00:04
Well I do have spark,just not getting gas to the cylinders. I took the carb apart and the float would not move up or down because of a tab that was holding it in place on the side where the rod slips thru, strange. Anyway I bent that out of the way and now at least I am getting gas into the bowl but still not up into the cylinders. Any suggestions? Thanks for the help figuring out my magneto.
TDillon
10-13-2005 08:06:28
 Re: Case ScC I have spark No Gas! in reply to RShaips, 10-11-2005 16:00:04
Check the air intake on the carb by disconnecting and hold your hand over it as it cranks. Suction should be there to get gas from carb to cylinders. If spark plugs are wet, maybe your plug wires are not correct. Firing order must be correct.
