Case 730 ?
segrat1
10-11-2005 09:18:09
I just bought what I believe is a Case 730 tractor.The serial number is 8247479.It also says 741C on the tag. Can someone tell me what year and model this is for sure. I would like to put new pistons and sleeves in it (not sure if it has sleeves)but all the kits I see on the internet are for disael. Can someone point me in the right direction? Also is it possible to transplant a diseal motor into this if the gas motor is shot? Thanks, John
Roger H
10-11-2005 13:27:57
 Re: Case 730 ? in reply to segrat1, 10-11-2005 09:18:09
Hi John, yes you have a 730 with Case O Matic, it is a 64 model, the second digit in the model # indicates what fuel somewhat,the 4 indicates gas or propane, if yours was a diesel it would read 731C. you can still get sleeves & pistons, unless there is someone out there that has them, you might be able to only get them from Case, for some reason spark ignition engine kits are not as plentiful but everyone seems to have diesel kits. You should be able to put a diesel in it. If you have any more questions. post back here & someone will help. Roger
segrat1
10-12-2005 08:50:23
 Re: Case 730 ? in reply to Roger H, 10-11-2005 13:27:57
If I decided to go diesel what engine would I be looking for? Would it be a 267? What equipment would have them in it? Thanks, John
Richard E.
10-12-2005 14:22:58
 Re: Case 730 ? in reply to segrat1, 10-12-2005 08:50:23
Yes, mine is a 267, I completely re-built mine including both heads, used too much either over the years. With the new rebuild all she needs is the glow plug, and threw away the either ! My 2 cents...
INCase
10-11-2005 13:21:04
I had been searching for piston/sleeve kits for my stuck 730 before I found other alternatives to rebuilding it (different engine). I believe Clevite has them. See post below for Case 800 heads. There is a dealer mentioned in there. Yes a diesel will fit but will need another fuel tank, starter, maybe a 2x battery tray and some other misc. components. Good luck
