Case 800 transmission fluid level question
INCase
10-11-2005 07:57:58
I believe I read that since the 800"s have no dipstick for the trans/rear fluid level that there are level plugs. Where are these located? thanks.
c hess
10-14-2005 18:32:53
 Re: Case 800 transmission fluid level question in reply to INCase, 10-11-2005 07:57:58
Might try looking around rear close to hyd an pto Case has used a 3/8--1\4 pipe plug in past on some tractors . 830 HOLDS 18 gallon .hvd fluid Appreciate comback
c hess
10-12-2005 08:16:25
Evervone needs a response so all ican say is 830HAD dip stick on filler cap on top of trans case on left side close to seat mounting. Seen 800 but cant remember.
INCase
10-14-2005 10:38:05
 Re: Case 800 transmission fluid level question in reply to c hess, 10-12-2005 08:16:25
Thanks for the reply C hess. . I ask alot of questions here and don"t always get replys. The 700/800"s don"t have the dip stick..
