Draining the block of a 38 Case
canuck_case
10-10-2005 18:54:31
Its getting cold up here in Canada. Does anyone know the location on the block to drain the water out?
Thanks,
Kelly
john anderson
10-10-2005 19:44:42
 Re: Draining the block of a 38 Case in reply to canuck_case, 10-10-2005 18:54:31
WELL THE ONLY WAY THAT I FOUND OUT ON HOW TO DRAIN WAS TO TAKE OFF HOSE ON BOTTOM OF RAIDATOR. THATS HOW I DRAIN MY OLD CASE. I DID NOT SEE ANY DRAIN PLUGS IN THE BLOCK. MAYBE THIS MIGHT HELP YA.
AllanC
10-10-2005 21:40:46
 Re: Draining the block of a 38 Case in reply to john anderson, 10-10-2005 19:44:42
If It's an L (and likely all are the same) you need only drain it at the radiator plug. The lower hose connection is at the lowest place on the water jacket so that will drain the block too.
