Question for South Texas Case
musicman44
10-10-2005 17:23:32
A few weeks ago you posted that you pull an 8 row ripper bedder with your 2590. Would you describe this tool for me? We don't see these things in Illinois. What crops do you raise? Thanks
South Texas Case
10-10-2005 21:25:07
 Re: Question for South Texas Case in reply to musicman44, 10-10-2005 17:23:32
Music Man what we call a ripper bedder has a front bar with subsoiler shanks that run in the seed row and a rear bar that has lister or bedder shanks that throw the beds back up. I run the subsoiler shanks from 12 to 18 inches deep depending on the conditions. The rear shanks have high wing busters on them, they are run deep enough to make a good bed. The front bar is a ten inch pipe with brackets welded to it and back to the rear 4 by 7 bar. The rear shanks are JD high clearance shanks, it has row markers also. We built this plow in our farm shop, but there are some commercial ones down here too, most of them have disc bedders on the back. This is the only tillage pass we will make before planting, except we may put out liquid fertilizer in December, then we lightly run some sweeps on the fertilizer rig to clean and reshape the beds. Any other weed control is done with Roundup. We grow wheat, Roundup ready corn( which has taken the place of grain sorghum account of grass control), and beef cattle. The more fuel and fertilizer prices go up the more cattle I'll run. I hope this answers your questions if you have any more just ask. Tony
musicman44
10-11-2005 17:23:03
 Re: Question for South Texas Case in reply to South Texas Case, 10-10-2005 21:25:07
Thanks for the info. I have seen a rig in northern Illinois that has two sets of rolling disc blades (24" I believe) to throw up ridges. This is done in the fall before planting in the spring. "rear bar that has lister or bedder shanks" So you use shanks to throw up ridges?
Would this in high corn residue? Thanks.
South Texas Case
10-12-2005 15:38:10
 Re: Question for South Texas Case in reply to musicman44, 10-11-2005 17:23:03
Music Man the fields I just ran this rig in were corn stubble that had been sprayed with roundup then shredded about two weeks later. It usually goes through pretty good. Tony
