case 440 range shift problem
rhud
10-10-2005 14:19:57
the lady posted below needs a little help. i don't know anything about cases, just a david brown or two.. she has a case 440 with dual range gearbox. she had never shifted the range from high until last week. when she did, it failed to shift into high and now she cannot shift it back into low. she writes that it is stuck in d or drive.. not sure what that means. but tractor will not move..
she is homesteading way up north and needs a little help. anyone have any ideas. Thanks fellows,.
Roger (Mi)
10-14-2005 04:59:33
 Re: Dual range or triple range? in reply to rhud, 10-10-2005 14:19:57
Likely, the dual/triple range shift cover will need to be removed. Once the four cover bolts are removed, enough freedom can usually be found to move the shifting fork so that the cover can be removed. Check the shifting rail for proper movement. Bent fork? Good luck.
