Case 2470 Transmission Pops out of Gear
Nathan in Idaho
10-10-2005 10:01:53
I'm looking at a Case 2470 for sale that pops out of gear in lower gears. Can this be something simple(i.e. cheap) like clutch packs or bolts broken between clutch packs? Or a stuck check valve? Or does it popping out of gear show that its a bad gear?
Thanks.
jim handke
10-10-2005 15:28:58
 Re: Case 2470 Transmission Pops out of Gear in reply to Nathan in Idaho, 10-10-2005 10:01:53
Maybe the linkage is out of adjustment, this would keep one gear from meshing all the way. Also, a bearing going bad on the shaft will do the same thing.
