Hp. on a 830 case-o-matic diesel ?
Richard E.
10-09-2005 18:47:09
I already have a 730 case and am very happy with it. Is there a way to put power brakes on it ? My neighbor wants to sell me his 830 case, how much bigger is it than the one I already have ? Just wondering.
Jaker2
10-10-2005 07:40:06
 Re: Hp. on a 830 case-o-matic diesel ? in reply to Richard E., 10-09-2005 18:47:09
They sure are good tractors. The Case-o-matic is the berries. Do you happen to have the serial number off of it I am looking for a twin to the one that I have. I am looking for one with a number of 8192180-8192185. I would like it to be in that range as I have contacted case and was told they these models were equipped just like the one that I have.
Richard E.
10-10-2005 09:21:51
 Re: Hp. on a 830 case-o-matic diesel ? in reply to Jaker2, 10-10-2005 07:40:06
Jake, yours looks to be a 1962, mine is a 1965 and the neighbors is a 1967. Mine has flat top fenders & 3-point hitch, his has clam fenders and eagle hitch.
Jaker2
10-10-2005 15:49:45
 Re: Hp. on a 830 case-o-matic diesel ? in reply to Richard E., 10-10-2005 09:21:51
Yep, mine is a 62. I do not think I understand you quite right. You said you neighbors is a 37 with eagle hitch and clamshells????? How can this be? Are they both Comfort king models??
Richard E.
10-12-2005 16:58:08
 Re: Hp. on a 830 case-o-matic diesel ? in reply to Jaker2, 10-10-2005 15:49:45
1967, I"m not too sure if they are what you call"clam shell" or not. I do know they aren"t like mine, large flat top like the big I-H"s have. My dash and steering wheel seem to set slightly ahead of the rearend . His favors closer to over rear of the axle.....
c hess
10-10-2005 06:06:58
Late 830 were rated @65hp. Had 301 cu in engine an weighed about 7200 lb with wide front. One of best ever made!! As for brakes no power brakes avaible. However i think if you completely take apart an clean balls an guides an replace with new lining you will be pleasently supprised. Note mine is 64 model with 35 gal tank case-o matic
noeohiocase
10-21-2005 09:17:29
 Re: Hp. on a 830 case-o-matic diesel ? in reply to c hess, 10-10-2005 06:06:58
C,
I just bought a 801b and would be real interested in seeing a pic or 2 of your 830? This will be my 1st attempt at a restoration but I did do a rough restore on my mother's 511b.
Richard E.
10-10-2005 07:12:33
Thanks for the information. It seems to be a good runner, the eagle hitch will be something different to get used to. I may just give her a try soon..... .
