Case L - Zenith carb drain plug
Steve (DE)
10-09-2005 15:20:36
On the Zenith K6 carb used on the case L (1935-1938) there is a hexagonal drain plug on the bottom. If you unscrew the plug, there is some sort of porous stuff in it. In mine there is also a hole, a bit less than 1/16" dia., clear through. Should this hole be there or has a previous owner poked it through? Should I be able to see light through the center of the drain plug if I hold it up to a light?
Note, the later K6 carbs didn't have the external drain plug, a drain was integral to the bottom of the carb.
Thanks.
canuck_case
10-10-2005 18:52:46
 Re: Case L - Zenith carb drain plug in reply to Steve (DE), 10-09-2005 15:20:36
I just rebuilt a K6 but it doesn't have the drain plug. Mine is off a 38 case L, and I am not sure if I need to find a drain plug as it tends to leak out periodically.
KD
