Tire Size On DC AWF
Glenn FitzGeral
10-06-2005 18:55:14
I have an adjustable wide front on my DC. Today I put on different hubs allowing me to use the factory weight wheels. My weight wheels have 7.50's on them now and they are too wide. They are pressed HARD against the tie rod. What is the biggest size I could get by with? I do not want to turn the wheels backwards. Could I use 6.50's...7.00's...? I plan on pulling a mounted plow and will be needing the extra 300 lbs. on the front. Thanks, Glenn F.
george md
10-06-2005 19:04:37
 Re: Tire Size On DC AWF in reply to Glenn FitzGerald, 10-06-2005 18:55:14
Glenn,
The biggest you can wear on the wide front with
cast wheels is 5.50 X 16 . that is what is on
it when new.
george
Glenn F.
10-06-2005 19:38:22
 Re: Tire Size On DC AWF in reply to george md, 10-06-2005 19:04:37
Thank you George for your quick reply. I will check on getting a pair of them tomorrow. Glenn F.
Doug Boll
10-09-2005 06:03:24
 Re: Tire Size On DC AWF in reply to Glenn F., 10-06-2005 19:38:22
The adj. fronts I have seen (and owned) had pressed front wheels on them. 5bolt SC pattern. 6.00x16 fit just fine.
