Case o matic
gayle
10-06-2005 15:56:32
anyone ever pulled with a case o matic ? if so how did it do I have a 411 WITH ONE MAY TRY PULLING WITH IT
wayne2
10-07-2005 07:15:49
 Re: Case o matic in reply to gayle, 10-06-2005 15:56:32
Heard, Wasn't there but case-o-matic first introduced they were banned from serious pulling. Green-Red-Yellow-Orange tractor guys JEALOUS-just what I heard. Wayne
mike's600
10-06-2005 17:12:22
I pulled my 611 B , it pulled good, just slow.
You need to get that tractor in the light classes.You will be underpowered if you pull it at it's factory weight.
Lincoln
10-06-2005 18:41:13
 Re: Case o matic in reply to mike's600, 10-06-2005 17:12:22
Just curious, did you pull with in Case-O-Matic drive or direct drive?
mikes600
10-06-2005 20:06:22
 Re: Case o matic in reply to Lincoln, 10-06-2005 18:41:13
started in case-0-matic, went to direct, back to case-o-matic.
The 800 case-omatic did better in direct drive
caseman-d
10-07-2005 21:33:37
 Re: Case o matic in reply to mikes600, 10-06-2005 20:06:22
Mike,
I pulled my 800 in the 8500 and 9500lb class. I pulled in first direct in the 9500lb class and 2 gear direct in the 8500. I put 18.4-38's on it and it still would spin out.
Why is it the 4 cylinders had such good power and all my 6 cylinders power out. Seems like the 4 cylinders had much better pulling power.
caseman-d
