Turbo's on a 1030???
Seth Mitchell
10-06-2005 07:11:28
Ive been wondering,,, what kinda Hp can you expect from a 1030 when you add a turbo???,,,, I know that 1070s with turbos get at the least around 120 Hp,,,,, Id imagine that a 1030 would be a bit less.
Thanks in advance
Seth Mitchell
Jeff FromWI
10-08-2005 09:15:08
 Re: Turbo's on a 1030??? in reply to Seth Mitchell, 10-06-2005 07:11:28
Hi Seth, The 1030 heads were not designed for a tubo. On the Case 1200 TK 4-WD with the same 451 diesel Used in the 1030 Case used a Diff Head design. More of a dirrect Injection.
Seth Mitchell
10-07-2005 12:54:54
140 Hp dosnt seem quite safe for a workin tractor,,,,, ,,,,, But Case blocks are stronger an should handle it. Id imagine thats with the fuel pump turned up a bit Lamont,,,,, , Thanks for that input.
I think I like the 120 range like Jim had mentioned,,,,, ,,,, Id like to have one some day to wor along with my 930,,,,, But It will have to have a turbo on it,,,,, ,, Id really like to find one with the Elwood front wheel drive axle,,,,, ,,,,, ,, Thanks for the input guys.
Lamont
10-07-2005 10:36:28
140 or so !!!
jim handke
10-06-2005 15:12:44
My first tractor was a 1030 with a M&W turbo. It had 122 h.p. at factory pump setting.
