VAC light switch
MikefromIowa
10-06-2005 06:56:02
OK, I'm in need of replacing my 3 position light switch. the only ones I can find are about $60. I can buy the original on/off switch used on later VAC's with a regulator for about $15 from Case. So, Does anyone know where I can get a 3 position for cheaper? or I will be converting my cutout to a regulator. My cutout seems to work fine. I'm sure a regulator would be much cheaper than that switch.
Eric Foster
10-07-2005 12:23:52
 Re: VAC light switch in reply to MikefromIowa, 10-06-2005 06:56:02
Mine went out too. I just got a 3 position toggle switch from the local auto parts store and a 100W, 3 ohm power resitor from an electrical parts distributor. I think it was around $15. It's ugly, but it can be hidden in the compartment under the battery box.
One position is off, one is trickle (field through resistor to ground) and one is full charge (bypass resistor & go straight to ground).
jal-SD
10-07-2005 06:56:42
Go to your friendly JD dealer & ask him to order you a switch for an early A, B, or G with a cut-out generator. Its the same switch. Got one for my '46 VAC about a month ago. Took about a week to get it. $43+ change, as I remember it. You might want to get a picture of the JD wiring diagram for an A, B, or G of the same vintage. My VAC's wiring was a mess, & the manual's picture I have left a lot to be desired. I wired my VAC the same way as a digram that I got from a friend for a G-JD. Now my VAC's charging system thinks its a JD, but it works great. (My $0.02 worth. jal-SD)
John T
10-06-2005 13:55:00
Mike, you may wanna price a Voltage Regulator also cuz they arent cheap. If you do decide to convert from a cutout relay and light switch type controller over to a full fledged 3 or 4 terminal Voltage Regulator, be sure n get one thats compatible for whatever ground youre running at, Pos or Neg. Some work at either while others may not.
Also, if you happen to have a 3 brush generator with the adjustable third brush and youre gonna change to a VR, I would set the adjustable (if it has one) third brush to the Maximum charge position.
Sounds easier to get the correct switch maybe??? Have you tried Agri Services for those light switches????? He has em for JD but not sure for case???
John T Nordhoff, retired electrical engineer in Indiana
F-I-T
10-08-2005 16:24:29
 Re: VAC light switch in reply to John T, 10-06-2005 13:55:00
Ditto, john! A good quality VR will be in the neighborhood of $45.00
Frank-in-Tallahassee-whose-VAC-is-now-charging!
MikefromIowa
10-06-2005 14:17:05
John, Thanks. I do have the 3rd brush generator. I can get a 6V positive ground regulator for an old GM from NAPA for about $30. I've read how to adjust the 3rd brush, but and still lost on actually how to do it. I will try Agri Services also.
John T
10-06-2005 16:27:38
 Re: VAC light switch in reply to MikefromIowa, 10-06-2005 14:17:05
Many of the adjustable type 3 brush generators have a plate that you loosen 2 or 3 screws then rotate it to move the 3rd brush close as possible to the other brush near it.
John T
GeoMo
10-06-2005 11:15:46
If this is a "working tractor";
Convert it to 12 volt with alternator.
MikefromIowa
10-06-2005 12:17:31
 Re: VAC light switch in reply to GeoMo, 10-06-2005 11:15:46
I can see no reason to convert it to 12V. it starts almost before I push the starter. I don't have to use it in the winter, but it gets used serval hours a week mowing lawns.
Don Livingston
10-06-2005 08:44:48
That price is about as good as it gets. Cole Hershey builds them. Made in the USA.
DonL.
scott vaughan
10-06-2005 19:04:06
 Re: VAC light switch in reply to Don Livingston, 10-06-2005 08:44:48
How does one get ahold of Cole Hershey.
Thanks
Scott
Don L.
10-07-2005 09:16:34
 Re: VAC light switch in reply to scott vaughan, 10-06-2005 19:04:06
They don't sell direct to the public, and there is a large min. quanity to get the switch.
Don L.
Hank (MO)
11-15-2005 04:27:47
 Re: VAC light switch in reply to Don L., 10-07-2005 09:16:34
This may be a dead post by now, but I just went through this trouble myself... for a slightly different reason.
I want a new "ignition" switch for my 46 VAC that will allow me to use a 12 V alternator and a 3-Wire setup. For those of you that don't know, a 3-wire setup provides fully regulated voltage (i.e. ~12-13 volts instead of 17 with a 1 wire) and eliminates the need to rev your cold engine to excite the alternator (as is needed on a 2 wire setup). Many people accomplish this by stringing a light bulb or diode in series (bad idea in my book).
The best solution (in my opinion) is to get a double pole single throw DPST switch that looks just like the original. Now where to get em...
Cole Hersee (not Hershey) makes them. Model #50047. They do not sell to the public. However, I contacted a Freightliner parts dept. and told them I was rebuilding an old tractor (not a lie) and needed this switch. They had it in stock, $15.00. Not cheap, but a solution.
Now the switch that it sounds like your are talking about for lights also seems like a push / pull type switch. If it has 3 "positions", then it is likely a single pole double throw (SPDT). Guess what, Cole Hersee makes MANY of these as well, and your good old Freightliner parts dept. can get them as well.
Good luck.
