Oil seal behind brakes
John in Ne.
10-04-2005 07:02:56
I have the right hand brake assembly off of my DC.Can I remove the casting going into the transmission case to get the oil seal out? My manual isn't very clear on this part. It looks easy to remove but is it much to install again? Or will the large splined shaft stay in place? I hope this is clear enough to understand what I'm asking. John.
dctom
10-04-2005 10:31:25
 Re: Oil seal behind brakes in reply to John in Ne., 10-04-2005 07:02:56
John; the diff shaft will fall but it is not too hard to raise it back up and slide the plate back where it belongs, caution only do one side at a time tom
John in Ne.
10-04-2005 12:46:47
 Re: Oil seal behind brakes in reply to dctom, 10-04-2005 10:31:25
Thanks,It kinda looked like that was the case. Will my CNH dealer have these seals,Or would a bearing jobber be a better deal? John.
dctom
10-04-2005 16:13:12
 Re: Oil seal behind brakes in reply to John in Ne., 10-04-2005 12:46:47
Either place will have them mill supply probley cheaper tom
L.Lamp
10-04-2005 19:36:43
 Re: Oil seal behind brakes in reply to dctom, 10-04-2005 16:13:12
Just a word of caution. Put some thin shim stock over the splines BEFORE you slide the seal and bearing carrier back into place. If you don't, the splines will cut the new seal and it will still leak, believe me!
John in Ne.
10-05-2005 08:37:51
 Re: Oil seal behind brakes in reply to L.Lamp, 10-04-2005 19:36:43
Thanks for that advice,It wouldn't have ever crossed my mind to do it.When I pulled the part with the seal in it out there were 14 thin shims behind it. That seems like alot (?) Is it? John.
L.Lamp
10-05-2005 19:22:50
 Re: Oil seal behind brakes in reply to John in Ne., 10-05-2005 08:37:51
If there was no play in the splined shaft, the shims should not be messed with. They control the fit of the roller bearing you can see when the carrier is pulled out to install the new seal. After you have the new seals in and all tightened up, check for up and down play and in and out play. Remove shims till play is gone but bearing is not binding. A tiny bit loose is better than too tight.
John in Ne.
10-06-2005 06:52:37
 Re: Oil seal behind brakes in reply to L.Lamp, 10-05-2005 19:22:50
Thanks to all for your help.These seals are about the only leaks on this tractor,other than finding a few missing parts,this should be a pretty easy rebuild.John.
