Case VAC hand crank....
Cases n Harleys
10-03-2005 21:06:49
Would any of You folks out there know where I could find a hand crank for a vac that I could purchase reasonably? Thanks in advance.
Gary Cash
10-03-2005 23:44:38
 Re: Case VAC hand crank.... in reply to Cases n Harleys, 10-03-2005 21:06:49
Start with 3 pieces of 1/2" i.p.s. galvanized steel pipe, 1 @ 18" long, 1 @ 9" long, 1 @ 6" long and 2 ea. 90 degree 1/2" i.p.s. threaded couplings. Drill and tap one end of the 18" pipe (about 1/2" from the end) to accept a 1/4" diameter grade 8 screw. Insert the screw and cut off the head so about 1/4" is exposed at each side of the pipe. Assemble the pipe pieces to form the crank (18" piece to coupling to 9" piece to coupling to 6" piece). Tack weld the couplings to the pipes. Bevel the end of the pipe with the screw through it to guide it into the tractor's crank socket.
Makes a servicable crank.
Good luck.
