More 900 Power Steering questions
Iowa Rick T
10-03-2005 20:28:36
Ok. I have installed a used power steering pump and new hoses on my Case 900.
Started tractor and found that I can turn to the right easily, but it absolutely will not turn back left (even with some force).
Is the control valve bad? Is it rebuildable or do I look for a salvage yard piece? Is it possible I hooked the hoses up backwards on the control valve? I put the high pressure line on the inlet towards the front of the control valve. Was this right?
I had put new power steering fluid in prior to starting tractor. Fluid is now "whitish" - I assume that water would have been in the cylinder or control valve?
Any and all help is greatly appreciated!
