case DC questions
WisconsinJJ
10-03-2005 15:02:12
Was wondering if anyone could clue me in.....found a case dc for sale serial number 5519192...stout looking machine pto some sorta 3pt and hydraulics the hydro. pump is located just below the pto is it live? and is it live pto what year is this machine? Sorry but i know absolutly nothing about case tractors and little in general about tractors. but it seems like a good deal sheatmetal is there and straight tires decent unfortunatly a narrow front how hard and expensive is a wide front to get? thanks for all the help..... i have pics that i could e-mail if it would help in explaining this tractor.
Thanks again JJ from Wisconsin
John Can't use my name
10-03-2005 16:05:18
 Re: case DC questions in reply to WisconsinJJ, 10-03-2005 15:02:12
Its a 1951 model with hydraulics and no three point (eagle hitch, Case three point). Eagle hitch, and live power was added in 52. The hitch you see is a two arm unit for specific implements.
Camboted
10-03-2005 16:01:52
The serial number indicates it is a 1951. Post "DC Tom" for details. Some of the late models had live PTO and "knockouts" for the rock shaft for Eagle Hitch, which came out in 1952. If it has live PTO, then it also has a chain drive, live hydraulic ststem, probably a single valve although some had two valves.
Wide fronts come in several varieties, the easiest to find is the conventional DC-4 configuration which puts the front end under the radiator (you should be able to get one for $200), very late models came with the same axel, but with a "heart shaped" casting that put the front end about a foot forward, they are hard to find, but you could proably locate one for $400. (with either of these make sure you get the steering arm off the gearbox, and the "chicken roost", plus the crank, as they are different than what you have. Then there is the adjustable wide front, it sits out front like your narrow front, uses the same crank, but is a fully adjustable axel that was popular with vegetable farmers. These will also cost about $400 +or- and can be hard to locate. If you want to locate one of these put out a post on the forum, someone will jump on. LOL!
