Case SC
Ron LeVine
10-03-2005 10:05:37
Greetings all,
I was just given a Case SC. The fellow had it on his property for 20+ years and never used it.
1) is there a three point hitch available that will work with it?
2) the clutch seems to be frozen. I have the side cover plates off and the pressure plate seems to be deactivating the clutch just fine, but for some reason, the disk itself is stuck. Is there a way to unstick it without removing the engine?
I don't know if the engine runs or not yet. It had about 2 hours on a fresh rebuild when the guy parked it 20 years ago. I will be draining the oil and pulling the carb off and rebuilding it before I try to start it.
Finally, it seems to be stuck in a gear. I have tried to move the shifter with the clutch both in and out and it is simply locked into place. Is there something that I am missing?
With regards, Ron
Camboted
10-03-2005 12:23:26
 Re: Case SC in reply to Ron LeVine, 10-03-2005 10:05:37
Your clutch is probably stuck to the flywheel, see the post below on the DC clutch. Now, regarding being stuck in gear? Does the shift lever move? Does it sound like it is moving gears around? If so, your problem could be stuck brakes. Pull the drums and free them up.
Do you know why it was parked? If not, the problem could be a broken drive chain. That will mean pulling it apart. Get yourself a manual.
Now, concerning starting the engine. if it has been sitting that long, pull the plugs and put a cup of auto trans fluid in each cylinder, do not replace the plugs, then pull the valve cover and make sure all your valves are loose, oil them up. Let it sit a few hours and then see if it will turn over. If not, remove the rocker arms, find a cylinder near the top of the stroke, and do a search on this forum for DC Tom's formula for a stuck engine. It uses hydraulic power, and it is slick.
ROn LeVine
10-03-2005 14:05:59
 Re: Case SC in reply to Camboted, 10-03-2005 12:23:26
Thanks for the reply.
The brakes aren't stuck as the tractor moves fairly easily and that is how I got it on the trailer to bring it to my shop.
The shift lever is stuck. I.E. doesn't move at all. I am thinking that I will have to pull the top off the transmission to free it unless someone has a better idea.
The plugs were pulled and a cup of Marvel Mystery oil was poured in. The only thing that concerned me was that the #2 cylinder was completely full of water and I had to syphon it all out before putting the oil in.
Thanks for the hint on DC Tom's formula. I will check it out.
Thanks a bunch,
Ron
