310B Eagle Hitch Control Stuck
Scott Flynn
10-02-2005 15:55:09
Recently filled the torque tube up with oil and restarted the tractor. Had a high pitched squealing noise. Figured it had to be the bypass on the hydraulic pump. It appears that the Eagle Hitch lever is stuck in the raise position. I figure this is causing the pump to bypass when the hitch reaches its full height. In a quick thinking moment, I put the pump out of gear for a temporary solution. Anyone have any ideas of how or why the lever might be stuck in the raise position? I'm afraid that I'll have to take off the fuel take and take the valve apart - may be the detent ball is stuck. Any other thoughts?
case poor in pa
10-05-2005 16:28:40
 Re: 310B Eagle Hitch Control Stuck in reply to Scott Flynn, 10-02-2005 15:55:09
to much oil maybe? you put in? 12 quarts aint it?
Scott Flynn
10-05-2005 18:47:13
 Re: 310B Eagle Hitch Control Stuck in reply to case poor in pa, 10-05-2005 16:28:40
I only filled it to the fill point (full) on the dipstick. I don't remember how much that was now.
