VAC oil filter supplier??
Eric Foster
10-02-2005 12:18:25
All,
My local Wix supplier tried to cross reference a Carquest filter I used for my last oil change. He was not successful. I had a Carquest 85104 which seemed to work OK, but I think I still had a small clearance issue between the filter and the governor/throttle linkage. The Wix number s a 51104, but shows up as an obsolete number.
Where do I go??
Thanks,
Eric
Bill-KCKs
10-04-2005 12:59:44
 Re: VAC oil filter supplier?? in reply to Eric Foster, 10-02-2005 12:18:25
One more--Baldwin T-300M
MikefromIowa
10-03-2005 05:59:44
Yep, I second Joe. NAPA. its a wix filter. Its about $11.00 here in Rural Iowa
John Saeli
10-02-2005 14:33:46
Hey Eric: We stock that Filter in Fleetguard.
Joe (Wa)
10-02-2005 12:30:57
Napa 1104 is Wix's 51104. That's is the one I use with the original Case factory base. Napa 1101 (Wix 51101) is also compatible.
Joe
Eric Foster
10-03-2005 09:21:11
 Re: VAC oil filter supplier?? in reply to Joe (Wa), 10-02-2005 12:30:57
Thanks for the help guys.
Wix - 51104 & 51101
NAPA - 1104 & 1101
Carquest - 85104 & 85101
I believe these are all Wix filters. Thanks again.
charley hellickson
10-03-2005 22:23:02
 Re: VAC oil filter supplier?? in reply to Eric Foster, 10-03-2005 09:21:11
my local store owner says carqest filters are made by wix.my son buys them from him and it says wix on the box.
mj
10-03-2005 19:05:30
Fram is a C-159.
Eric Foster
10-04-2005 06:01:08
 Re: VAC oil filter supplier?? in reply to mj, 10-03-2005 19:05:30
That Fram number is good to know. I didn't like the fact that all the others are made by one company (Wix). If they decide to cut costs, I'm sure our little oddball filter will go away.
wayne2
10-04-2005 20:11:24
 Re: VAC oil filter supplier?? in reply to Eric Foster, 10-04-2005 06:01:08
Some of your younger parts guys know it as filter w/popscicle stick. Wayne
