Rebuilding Zenith carb for Case L
Steve (DE)
10-02-2005 10:19:39
Anybody know of an online set of directions on rebuilding the big Zenith carbs they put on the Case L after about 1935 or so?
Fred in Utah
10-02-2005 12:45:08
 Re: Rebuilding Zenith carb for Case L in reply to Steve (DE), 10-02-2005 10:19:39
I would like to know where to get a rebuild kit for the Zenith Carb on my 44 LA. How much should I expect to pay for it? Will the same online car rebuild instructions apply to my LA? Thanks
Steve (DE)
10-02-2005 16:06:33
 Re: Rebuilding Zenith carb for Case L in reply to Fred in Utah, 10-02-2005 12:45:08
It was the same Zenith carb on the later L's and the LA's. There are always a few repair kits available on e-Bay in the "buy it now" category of stuff at about $22. You can also get them from Dave Reed at Otto Gas Engine Works.
Walt Davies
10-02-2005 21:59:31
 Re: Rebuilding Zenith carb for Case L in reply to Steve (DE), 10-02-2005 16:06:33
got to ebay.com and enter case tractor la at the search. You will find lots of repairs kits for the LA L carb they are very simple arbs to repair.
Make sure that you get all the jets and such cleaned good.
Walt Davies If you have trouble get in touch with me at [email protected]
Ian@IVS
10-03-2005 15:16:07
 Re: Rebuilding Zenith carb for Case L in reply to Walt Davies, 10-02-2005 21:59:31
Getting the carb clean is the biggest issue. Take the time the carb deserves by completely disassembling the unit. I made my own gasket on my L, the float was ok, and stole the rest from JD cerb kits. you can and should adjust the float contrary to what the owners manual says. attach a piece of clear tubing to the drain for a gauge.
